A few pics for y'all
I lowed it this weekend in the front. Prepping it for the new wheel combo
Almost 1.75 inches lower in the front now.
Not sure if I am going to lower the rear, I could use opinions on that
The opinion on that can vary ALOT. If you are going to run same size tire at all 4 corners I would bring the rear down to level or slightly raked. If you're going with taller rear rubber then wait and see how it looks and go from there.
Mopar to the bone!!!
