Seems the battery is loosing its charge over night. I am going to take the battery back to Sam's Club and have them load test it. Sorry for the long blog.
(1) As you're doing slo charge it till it's up which it has to be for a valid load test & maybe they can test it for you on the spot rather than you having to make a return trip if they had to charge it. (2) After dark with doors shut/everything off with that or another battery in there, take off a batt cable & see if you see a spark & if so there is a draw that is draining the batt & there would have to be for it to go dead that fast unless the batt is really kaput. (3) that ain't a long blog! (not even close ). some of the symptoms ain't (quite) adding up completely & the battery is always the first item to confirm. It'd sure be nice if you could borrow another one for an hour or so. Holler with any news
