No, I checked the end that bolts to the radiator support. I did not pull the intake manifold bolt end. I did replace the start relay and shorted the two posts. All I got was some sparking. No engine cranking. Guess I should have the battery tested or maybe I will go buy a new one. I will report my results. Thanks for all the help.
