I'm still not sure what you call excessive drag.
Is there some way you can quantify the problem? Can you turn the wheel by hand? Can you spin the wheel without it stopping immediately upon release?
If I spin the wheel with a good hard spin, it will rotate on its own for about one revolution.
that's fairly excessive I would think too....it would cause excess heat and faster wear on the pads/rotor.
I had a similar issue with a bad rubber brake line, have you changed those too?
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
