Maybe you checked already, but make sure your pedal is coming back all the way. When I changed over to manual brakes and aluminum master on my 68 dart my front brakes were dragging too. After bleeding them half a dozen times I just happened to grab the brake pedal and pull it up. Over the years it wore into a spot and would not come back on it own.
