Also look for worn adapters (brackets). Sometimes the pads wear a groove that hinders retraction. Mill basturd (hadda misspell, Moparts would not allow correct!) file fixes that, also provides more inner pad clearance causing inner shoe to seize and crack pad material off when very hot.
