I 2nd the "you need different pistons" vote, much as the OP may not want to hear it.
If you're killing the quench, the CR needs to be even lower. You really can't band-aid it w/ a big-a$$ gasket to offset the dome's effect.
Hey "OP" - Are those the Victors you bought from me?
