.First the factory has a certain build process which includes being built on a highly engineered assembly Jigg, There is the full force of there resources to come up with a way of assembling for the best fit and finsh possible
you're kidding right... Half the original mopars I own and get in for resto work here look like they were assembled by drunks! Quality control was not Chryslers strong point...especially in the body, lead, and seam sealer departments!
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
