We're bringing a 68 charger back from the dead with all AMD sheetmetal here... Everything is loose fit for now but seems to fit pretty good, we are having a bit of a fit problem with the 1/4's to deck lid but the alignmet of the trunk latches and braces are out on our car so we're patiently getting them back "in shape" Like I said we're bringing it back from the dead! It'll have new rear rails,rear crossmember, trunk extensions, 1 peice tunk, valance, valance corners, tail light housing, deck filler, 1/4's, gutters,outer wheelhouses full floor, rear floor sections, and fenders... all AMD exept the extensions, I had them already! Thank you AMD, this one was a goner without them!
and a trunk lid, which is on the way!
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
