It is looking like a side-side swap and having to change the calipers to the same side bleeder/inlet type for me. There's no way this is going to work.
I'm going to be using the Hotchkis sway bar kit for the 67-72 K-frame. That kit mounts a lot like a 73-76 sway bar. Should fit fine.
I think Hotchkis may want to revise the directions on these.
I did see that the Shannon Hudson green valiant article in car craft had rear mount 10.87's on it.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
