Quote: If you had an auto valve body that worked well and you converted it to a manual shift (forward pattern) you would see no difference at all. If you convert to a reverse manual valve body that has no low band apply you may notice a slightly better ET if what you had before had some overlap.
Many variables will determine the outcome of this question.
Hutch
Lets not forget that it takes hp to drive the pump at a higher pressure
