Some people were asking for some info.
436ci 4.04×4.25
Block: Mopar R3
Compression Ratio: 11.43:1
Crankshaft: BPE
Connecting Rods: Scat 6.2-inch I-beam
Pistons and Rings: Total Seal .043/.043/3mm rings
Camshaft: Comp 250/252 degrees at .050, .735/.685 lift, 108 degrees LSA
Cylinder Heads: Brett Miller small CNC Mopar W9 363cfm max intake flow, 255cfm exhaust flow.
Intake Manifold: Mopar 420
Matt
Do you think you'll overpower that rod with this combo?
That crank has a 2.00 rod journal right? Didnt know scat made a 6.200 I beam with a 2.00 big end.
Don't know about the rods but everything I've read is stroke and speed. This thing is all done at 6500 rpm.
They do unless I was given wrong info. Matt
