trans in neutral, transfer case in neutral, and tow away. i added an air raid air filter kit, and throttle body spacer, and a tuner for the computer, and had no problems lighting them up. cat back exhaust, and i saw a slight increase in mpg. the main thing was quicker acceleration, and more torque on the low end.
weld some tow tabs on, or get some frame mounted ones, and get the light kit, so you can run the tail lights and turn signals, while towing.
"When Tyranny Becomes Law, Rebellion Becomes Duty"
