I also thought that the ignition timing was severely limited in the Magnum motors because of the problem of the belly pan on the intake blowing the gasket. The blown gasket would let oil in causing pinging and detonation. Mopars fix was to severely limit timing instead of fixing the gasket. Trucks already sold with the original decent timing curve received the "death flash" update when it would come into he dealership for service.
