The poly's will "walk" if there is any tolerance stack-up on strut rod, bushing or K. Adjustable strut rods will correct (mine did) as long as nothing is seriously off or tweaked.
When everything is snug, just check for clearance (eg LCA to K) and don't crank on it so much the LCA is pulled into a bind.
