yeah it pressed in hard and wanted to walk when i tightened up the pin bolt.
i think the issue is that the poly strut rod bushings are about 1.5x as thick as the originals, and i didn't have them tight enough so the SR length was/is too long.
i think between tightening down the SR bushings and shortening the SR length i should be OK here.
