I hear there are additives that work as well or better than zinc. Also that adding zinc to a properly formulated oil can actually hurt the level of protection you would get without it. I hope Leigh chimes in, his engine builder takes care of a lot of circle track racers, and had tried many oils and found one they like that works a lot better than the "known" good oils.
