embarrassing as it is, driven my 440 6pak mostly stock with much joy, now 535 stroker 700 hp, 6pak 727 3500 to 3800 stall w/RMV(which i never used before either) 3:55 gears,take some getting use to,so with this kind of power at the ready, thoughts on driving with power tips? i see others driving along at 20 or 30 mph, then stomping and tires light up, are they just stomping on it in 2nd,or downshifting to 2nd then stomping? basically looking to be schooled/educated on driving with a reverse manual valve body and 700 hp,and the fun to be had with it
