embarrassing question RMV
#1666163
09/01/14 01:52 PM
09/01/14 01:52 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
embarrassing as it is, driven my 440 6pak mostly stock with much joy, now 535 stroker 700 hp, 6pak 727 3500 to 3800 stall w/RMV(which i never used before either) 3:55 gears,take some getting use to,so with this kind of power at the ready, thoughts on driving with power tips? i see others driving along at 20 or 30 mph, then stomping and tires light up, are they just stomping on it in 2nd,or downshifting to 2nd then stomping? basically looking to be schooled/educated on driving with a reverse manual valve body and 700 hp,and the fun to be had with it
Re: embarrassing question RMV
[Re: meepmeep70]
#1666165
09/01/14 01:58 PM
09/01/14 01:58 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
You are going to have to drive around and see what it wants vs. what you want to do. But with that kind of power , if you are on street tires I think it will light them up at will in any gear. 20 m.p.h. roll ons in third should get exciting pretty quickly.
[Re: ScottSmith_Harms]
#1666166
09/01/14 01:59 PM
09/01/14 01:59 PM
meepmeep70
weymouth,mass.
700HP on street tires? When winter arrives, get into your daily driver, take it out onto a frozen lake, hit the gas a few times at various speeds. You'll get the picture pretty quick!
i actually run hoosier slicks ,the ones with two small treads
[Re: tubtar]
#1666167
09/01/14 02:01 PM
09/01/14 02:01 PM
meepmeep70
weymouth,mass.
Thanks, kinda what i was looking for
[Re: meepmeep70]
#1666168
09/01/14 02:04 PM
09/01/14 02:04 PM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
Just remember to never hit the loud pedal anyplace you wouldn't fire a gun. Or at least that's the way I view it. On street tires going WOT requires lots of space in front of you and at least 2 lanes of available space width-wise to allow some "wiggle" room. LOL Have Fun!!!! Be Careful!!!!
[Re: meepmeep70]
#1666169
09/01/14 02:04 PM
09/01/14 02:04 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
That will help (some) but don't get to compfy, that's a load of power to unleash on the street on any tire, if you get on it at the wrong time you might find yourself getting better acquainted with the nearest ditch or parked car.
THINK before making sudden moves! Be sure the car is 100% straight before getting on it hard, be aware of nearby objects, etc.
I'd recommend doing a track day event at your nearest race track where it's safe to play around a little so you can learn your cars potential in a safe environment.
[Re: meepmeep70]
#1666170
09/01/14 02:10 PM
09/01/14 02:10 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
It`s a blast................... Get to know your car and it`s new habits and enjoy. I can blow the tires off getting on the freeway...............
[Re: Thumperdart]
#1666172
09/01/14 02:19 PM
09/01/14 02:19 PM
meepmeep70
weymouth,mass.
NICE!
[Re: meepmeep70]
#1666176
09/01/14 05:07 PM
09/01/14 05:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
so with RMV, doing a burn-out or heating up my back tires, start in first shift quickly to second correct?
With a RMVB start in second and hit the throttle pretty good and shift to high.. your after 2 things.. cleaning the tires and heat... rpm is heat
