i actually run hoosier slicks ,the ones with two small treads
That will help (some) but don't get to compfy, that's a load of power to unleash on the street on any tire, if you get on it at the wrong time you might find yourself getting better acquainted with the nearest ditch or parked car.
THINK before making sudden moves! Be sure the car is 100% straight before getting on it hard, be aware of nearby objects, etc.
I'd recommend doing a track day event at your nearest race track where it's safe to play around a little so you can learn your cars potential in a safe environment.
