9.60 or even 9.40 is a LONG way from 8.90.
It's a long way away from 8.90 on motor, but not with a power adder. I'll never forget when Jason Bair was running 10 flat in that big old 67 Coronet, he put a nitrous kit on it, blew my doors off. When I looked at my time slip his side said 8.80 at 155.
Yep....... Your talking maybe having the power added make an additional 200 ponies over what the n/a configuration churns out. Not real hard to make 675 or better as good as the gen 3 heads are. Rick is making more than that easily.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
