I cut the entire top "hump" section off of my crossmember to fit my trans and rebuilt it with some 1/8" plate. 1.06 t-bars with a 440. been ok so far. I might want to go up to 1.12. The thing I wonder about is how much t-bar you can run without a cage/where the spring rate exceeds the chassis stiffness.
