Didn't know you had to change the coupler. Went from standard steer to power on my 72 RR and had to only change the shaft because of length. What is the difference in the coupler???
The input shaft on the steering boxes are different sizes.
Are you sure you did not change the coupler.
Can some one please confirm that the input shafts are different sizes?
Jason
