Re: power steering coupler interchange
[Re: CUDAJAS]
#1656398
08/08/14 04:24 PM
08/08/14 04:24 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
if we are talking about this: and talking about a Cuda, you'll need to change the coupler body just because the diff size of the steering box splined stud ( smaller on powered ), not really due the year. The year change was waaaaaay earlier Maybe will need to change the column shaft too? due the diff lenght? dunno
[Re: NachoRT74]
#1656399
08/08/14 04:40 PM
08/08/14 04:40 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
Yep that is the piece we are talking about.
I have already changed the shaft and the I know the standard coupler will not fit the power box.
My questions is what year did the stop using that type of coupler?
I have seen the aftermarket ones, but man are they pricey!!!
Jason
[Re: babarracuda]
#1656402
08/09/14 12:55 PM
08/09/14 12:55 PM
NachoRT74
Valencia, España
I have my serious reserve about those universal joints... On chassis cars they can work NICE, but not on unibody frames, since the body flex, and the Coupler designed by Chrysler allows this flex without affect the steering shaft assembly. That's the reason for this kind of coupler
[Re: Finoke]
#1656404
08/11/14 12:27 AM
08/11/14 12:27 AM
CUDAJAS
Hey Jason, I just went from power steering to manual steering. I have the complete original power steering coupling from my 70 challenger. It has everything you need except the roll pin that holds it on to the shaft.
PM me if interested. I will give you a good deal if your interested. Tom
Hey Thanks man.
I appreciate the offer. I really need one in the next day or so in order to make the big show (Moparfest) this coming Saturday.
Given you are in PA and I am in Canada, probably not gonna get here in time.
If I cant find one, I will let you know.
Jason
[Re: 72 RR DUDE]
#1656406
08/11/14 10:54 AM
08/11/14 10:54 AM
CUDAJAS
Didn't know you had to change the coupler. Went from standard steer to power on my 72 RR and had to only change the shaft because of length. What is the difference in the coupler???
The input shaft on the steering boxes are different sizes.
Are you sure you did not change the coupler.
Can some one please confirm that the input shafts are different sizes?
Jason
[Re: NachoRT74]
#1656408
08/11/14 01:07 PM
08/11/14 01:07 PM
CUDAJAS
well, you can actually try it right now... your actual coupler into the newer manual box... or simply measure the diameter input shaft on both boxes you have at this moment
yep, but I am at work and not near the car.
Everything I read indicated that you need a different coupler.
I will check tonight.
Jason
