Can't tell in pic. The AVS floats are taller.
You can heat the leaking brass float, stick it in water, and see where the bubbles come from to spot the leak. Then resolder where it's leaking.
Here's the one you need
One I have is waaaaay beyond repair. I don't need a hot water test to show me a ginormous 3 mm wide, 2 cm long crack.
Do you know where I can find the correct float?
And I figured the carb wouldn't be the original. Is there any reason this won't work properly on a 440 though?
[image][/image]
Bob
SWG
'68 Chrysler Town & Country, 'Katy Jo'
'70 Chrysler 300 2-door
'78 Impala 2-door
