Quote: All I can say is Wow! I had no idea how much difference a good torque converter could make. Between the lower transmission gears, the fine tuning on the distributor and the torque converter my car is now officially a beast! It's almost scary now. I hammered it and it would not stop spinning! It spun all the way into second gear! I even punched it once when I was moving about 15 mph and it lit up the tires! I just came back from about a 45 minute ride. I now have about half the tire tread that I started with.
I can't think everyone enough for all of the advice. I need to send an extra shout out to RapidRobert for all of his help. You guys are the greatest.
I wish you guys could have seen the ear to ear smile on my face when I was roasting the tires!
I have my sights set on a set of 3:55 gears. I can't wait to see how that does.
Your face is going to be stuck in smile mode every time you drive it now. At the rate of 1/2 a tire every 45 mins your wallet will hurt but you will still be smiling while you watch the tire shop install new tires.
would be a good time to add a torque strap to the engine, lube up the u-joints, spoon up the rear brakes now that it will launch faster.
