I just came in from about a 30 minute drive. Before I left I set the initial at about 26 degrees. All in is a little over 40, say 42 and in comes in fast! I did notice an ever so slight ping going up hill on full throttle a couple times. I think maybe setting the initial back a degree or so is probably in order. On my way home I was at an intersection and no one was around so I stomped on it. I laid down about a 20 foot mark on the pavement! That was no brake at all and it felt like it wanted to break loose going into second gear. Not too shabby!
I can't wait to get the new TC in and see how that does. I did notice a little pinging, not much but it was there. We will see what happens when I step the timing back just a tad.
That's King Weenie to you!
