Hello all finally working on my Bee again.When I got the car painted I had some old 295-65-15's on 15x10 weld pro stars 5.5 offset.I decided to go with wheel vintiques steelies 15x10 5.5 offset,with 285-70-15 from coker tire.put them on the car today they fit but they are damn close to hitting the fender on the front.almost looks like the rear is not centered?Or does this look right to you?
I measured and it seemed like these would fit,also saw a 68 roadrunner with these sorry no pic.his seemed to fit better?There is no weight in the back yet not tank etc..so why so much more space towards the rear?I really hope I dd not just make a huge mistake.The car has espo 1+ springs anybody running a tire combo like this?Does it work?pics?Its close enough on the front that I wont be able to install the wheel moulding.Really wanted the big and little look with as much tire as would fit.Hope I did not just waste $500
