Yep, A bunch of work for 15 more HP than the W5 mill..., but I guess if the water stays where it belongs, it will be worth it!
I would hope it makes more than a max effort 650hp w5 does.
Max effort W5 mill can make WAY more than 650. I say that because the one in my ex car made well over 700 on the Dyno and backed it up at the track by going 140 at 3200 pounds and change on S/S springs and a 28 by 10 Dot tire. That all said, heck yes...W8 has much, much more potential
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
