Matt what relays did you use (part #'s please). & it looks like you did not scrimp on the gauge sizes either
I don't recall the exact part numbers, and I don't have the car here to look at. But, I can tell you that they were 30 amp generic 5-pin bosch type relays. Though you only need 4 of the pins. But, the 5-pins are easier to get.
I think I went a bit overboard with the wire gauge. I used all 12 gauge. When I do the setup for my car I think I will use 12 gauge for the main power feed and ground, 14 for the lamp feeds, and 16 for the trigger wires. It'll be a lot less bulky that way.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
