Thank you. Yes a choke, no noticeable black smoke but I little eye burn from rich idle, not bad but you are aware of it in a closed area and I really haven't looked down the throttle of carbs since the Cuda is so frickin wide and only 5'7" or so and I'm not wanting to climb ontnhe fender.
