oh ok, just to clarify this is a complete different build. I am not changing from six pac to ly rods. the 2295s have all been balanced to the same as have the LY rods as well as shot peened, aftermarket bolts & resized etc etc. the factory fordged crank is ground .010 on all journals, the set just needs to be balanced complete.
The original question was Mallory weight needed?You won't know till the bobweight is calculated and the crank is spun on the balancing machine.
