What do you mean by "Switch on the transfer case" ???Is there something on top that supplies extra vacuum to move the actuator on the axle??I will pull the actuator off the axle and look inside more closely at the sliding collar...
Do Something..Lead..Follow..or get the {Beep} out of the way..
