had the same problem when I installed mine. you cant just crank the u bolts down with a finish torque on them. they need to be torqued slowly and evenly. I torqued mine in a crosshatch pattern 20ftlb at a time and each side til I got to the finish torque which I think was 80#. at that point when I set the car down it was level.
