Guys if this is a new install then the car has the preload in it because it was set up with a conventional spring. So the car was leveled with the torsion bars. So first time you let it down a lot of times it looks like a train reck. I would set it up on scales because you can make torsion bar adjustments and do your preload adjustments you can make the car level and have preload set.
JAKES AUTOMOTIVE
