How did you guys mount the sending unit for your aftermarket mechanical temp gauge into your small block performer RPM intake?? The sending unit threads are larger than any of the holes in the intake.
Do they sell a pipe fitting that adapts the threads from the larger sending unit to the smaller intake hole, or is it best to drill and tap the intake for the larger 1/2" NPT sending unit?
