I want to know if it is safe to use wheel spacers?I would also like to know if they can be used safely between the axel flange and rotor.I need to move the rotor outward to fit the caliper on properly.It would be good to know the minimum amount of stud required to mount the wheel safely.
410 pump gas solis flat tappet cam 10.95 so far
