"Rubber chunks in the fuel filter" sounds like a different problem than the fuel pump: sounds like a hose is disintegrating or has a tear in it that's allowing chunks to pass through the system. Not sure where your filter is plumbed into your system. My Holley pumps & Carter pumps have all been fine - for decades - as long as they were pre-filtered and haven't had to pass crud through them.
