The previous picture shows the TTi tail pipe installed with the Accurate R/T exhaust tip. I removed the TTI mounting bracket and made my own bracket that uses the U-Bolt bracket for mounting the exhaust tip. Now I have room for a resonator.
This picture shows the Classic Chambered Resonator #25-RES-SPE mounted to the R/T tip. Easy install!
1970 YO7 A66 [Canadian Export] F8 Challenger
340 (Currently in shop for stroker assy.)
