Y07_A66:
Not sure if you still wanted to see the axle side of the round mufflers, but here are a few. A couple of comments. Custom bend pipes allows the bends to go all the way to mating with the muffler, which helps reduce overall length. With slip-fit connections, there needs to be a few inch long straight portion for mating which makes the overall muffler length longer. There is a little over a finger width between the over-axle pipe and the shock. My mufflers are hung a little low to allow the turn down to get under the rear valence without pointing directly at the ground (which I did not want).
