Y07_A66:
I recently added Magnaflow 7" round X 14" case mufflers (3" pipes) behind the axle to my 70 Cuda. I do not have the Cuda cutout valence, so with the turn downs the mufflers need to be positioned a little lower, and are slightly visible from the rear of the car. The exhaust work was custom bend, but I was surprised by how much room there is, at least for a 14" case. If I had the cutout valence, I believe everything would have tucked up very nicely, and I might have been able to run an even longer case.
