I just got a "070" back from them and they do not use the correct colored seal(black) and the original aluminum finish is now the "Eastwood" special aluminum color.Otherwise the front ridge is correct looking and looks nicer then Fred's.I was not that impressed enough to change out the one I had Fred do.I had to "fluffed" up the fins to make them appear more correct on his also.So if anybody is looking for a fresh "070"......
