i know the repro isnt oe correct but i dont think you can see the face of it when on the car, and it does look alot better then the year one version
so for an almost $500 difference, i think for what my car is, the $200 repro will suit my car
thanks for your help
Exactly. And most every car I know that gets a clutch fan also get a fan shroud. So it's about impossible to see the face.
But you can see the fins on the back and side of the fan clutch. But it looks like those features are real close to OE??
Or, just pickup a Hayden version for $50.00 if you can live with it.....or buy the Mopar Performance Fan/clutch package for $100 or so. Though it's not a thermal clutch. But, I believe the fins look similar to the originals.
Use the Hayden 2765 for the $50.00 like he said. It is a thermal but you cant see the front of it which is also one of your points. DO NOT use the Mopar performance kit. It is 3 5/8" tall which will not fit most of the performance cars. It is patterned off a Dodge van with a 6 cyl.
