I've even soldered an auxiliary ground wire to the outside of the "socket" on the lamp. I had a 75 Ramcharger that had these very same problems and it was ALL grounds. I even ended up drilling a small hole in the lower panel that the lamps fit in and running a wire to the battery negative. That in itself solved the issiue permanently. Go figure.....
