Check the grounds as they are known for problems.then check the small contact that the bulb touches.Ive seen a lot sunk in the plastic.I usually pull them out and stretch the spring a bit to get better contact on the bulb bottom.Ive also had some that the case of the bulb wont ground well in the socket.I add a ground wire to the inside so the bulb gets better ground.Rocky
Chrysler Firepower
