It does look good but I see a weak link. With the way forces come into play the top 2x3 and the down leg 2x3 tubes welded joint, I think you would need a gusset. When I did my frame rails I cut the sides and inside face of the angle and then folded it in so the outside face stayed as one continuos piece and welding was only required on three sides. I really like this piece though as I want to give this a go for my car but ended up buying an Alterkation unit.
