Does anyone else know anything about these heads? I'm looking for 650ish hp while I have my car apart. They sure look tempting.Heres a question I sent to a head porter and the answer I recieved. (I have a set of Eddy rpms off of my 496 stroker they have had bowls
blended only. I would like to get as much flow as possible out of them
and still run them some on the street. What can you get out of them and
how much $ ?) (The answer was) (You already got the bowls done all i can suggest on them heads are as follows gasket match on heads and intake clean runners and blend everything and a 3 or 4 angle race valve job with a back cut on the valves and your looking at $500 to $600 on labor.I have anoher option since you have a stroker motor I have a set of fully cnc procomp heads that flow 345.6cfm @600 lift and they are sold for $1650 for heads, off set roller rockers, valve covers, head bolts, and valley pan.I dont think you would be happy spending this much money and not getting out of the heads what your looking for. I would be willing to help you either way you want to go.)
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
