Quote: The violet wire for magnetic pickup use isn't accidentally grounding out anywhere, is it?
good thought! another thing to try is hooking the white wire up to the dizzy wire and tapping first the wire to the points (looking for spark)and then shorting the points and look for spark. you did say when you tap the white to ground you got spark right?
