I run 1/2" spacers, mainly for the meth/water injection (and soon to be NOS) Not sure if they help or not, but even with the 1/2" spacers there's no way to use a stock hood. I think it wouls also depend on your set-up.
Ok Mr Yuck i will have to sheck and see how mutch clearence i have on my Challenger than whitout the spacers before i change the carbs Thanks for the warning ! Dident know it whas that tight
You might be able to get away with it on a Challenger w/ a bubble hood, but on a Charger even the stock unit pushes up on the hood insolation. Mine are open, if you do go w/ some, use an open spacer, I have 2 new ones I'll sell you cheap.
So if i understand you corekt the spacer is better whit an oval hole so i can just cut out in betven the holes !? How will this inprove ? It seems like the sharp two holes in the intake then will make distortion in that room of the spacers or what
