At Test&Tune at my track last year I carried my 315/60 M/T Drag Radials and my 29.5/10.5W's and ran them both and I ran a little over a tenth quicker with the drag radials.It hooked with both sets of tires. I only run 1/8 mile and my D-50 mostly runs low 6.30's at 2950 lbs.I do not think I will buy slicks again.
would this be the same for my heavy car? your 800 lbs lighter!
I am not sure about the weight difference, I really do not see what the difference would be. At my local track I run within a couple hundreds all night at T&T and when I bracket race. My problem is pulling the wheels straight up out of the lights on the hit then I cut a .490 something redlight.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
